Nikon yeni yazılım(firmware) 1.009 Distortion Control Üzerine D4 / D90 / D600 / D800 / D800E /D3100 / D3200 / D5000 / D5100 / D5200 / D7000 / D7100
Merhaba arkadaşlar nikon bir çok model için Distortion Control Üzerine dÜzeltmeler yaparak yeni Toplu yeni bir yazılım duyurdu.
Yazılımın adresi : http://nikonimglib.c...ata/#os-windows
Bu yazılımı kapsayan modellerin listesi aşağıdaki gibidir.
Yazılım gÜncelleme nasıl yapılır diyorsanız buradan yardım alabilirsiniz : http://www.nikonturk...elleme-anlatim/
Desteklenen lensler için aşağıdaki listeye göz atabilirsiniz..
â– Wide-angle zoom lens
AF-S DX NIKKOR 10-24mm f/3.5-4.5G ED
AF-S DX Zoom-Nikkor 12-24mm f/4G ED IF
AF-S NIKKOR 14-24mm f/2.8G ED
AF-S NIKKOR 16-35mm f/4G ED VR
AI AF-S Zoom-Nikkor 17-35mm f/2.8D ED IF
AF-S NIKKOR 18-35mm f/3.5-4.5G ED
AI AF Zoom-Nikkor 18-35mm f/3.5-4.5D ED IF
AI AF Zoom-Nikkor 20-35mm f/2.8D IF
â– Standard zoom lens
AF-S DX NIKKOR 16-85mm f/3.5-5.6G ED VR
AF-S DX Zoom-Nikkor 17-55mm f/2.8G ED IF
AF-S DX NIKKOR 18-55mm f/3.5-5.6G VR
AF-S DX Zoom-Nikkor 18-55mm f/3.5-5.6G ED II
AF-S DX Zoom-Nikkor 18-70mm f/3.5-4.5G ED IF
AF-S DX Zoom-Nikkor 18-105mm f/3.5-5.6G ED VR
AF-S DX Zoom-Nikkor 18-135mm f/3.5-5.6G ED IF
AI AF Zoom-Nikkor 24-50mm f/3.3-4.5D
AF-S NIKKOR 24-70mm f/2.8G ED
AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR
AI AF Zoom-Nikkor 24-85mm f/2.8-4D ED IF
AF-S Zoom-Nikkor 24-85mm f/3.5-4.5G ED IF
AF-S Zoom-Nikkor 24-120mm f/3.5-5.6G ED IF VR
AI AF Zoom-Nikkor 24-120mm f/3.5-5.6D ED IF
AF-S NIKKOR 24-120mm f/4G ED VR
AI AF-S Zoom-Nikkor 28-70mm f/2.8D ED IF
AI AF Zoom-Nikkor 28-70mm f/3.5-4.5D
AF Zoom-Nikkor 28-80mm f/3.3-5.6G
AI AF Zoom-Nikkor 28-80mm f/3.5-5.6D
AF Zoom-Nikkor 28-100mm f/3.5-5.6G
AI AF Zoom-Nikkor 28-105mm f/3.5-4.5D IF
AI AF Zoom-Nikkor 35-80mm f/4-5.6D
AI AF Zoom-Nikkor 35-105mm f/3.5-4.5D IF
â– Telephoto zoom lens
AF-S DX Zoom-Nikkor 55-200mm f/4-5.6G ED IF VR
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR
AF-S NIKKOR 70-200mm f/2.8G ED VR II
AF-S Zoom-Nikkor 70-200mm f/2.8G ED IF VR
AF-S NIKKOR 70-200mm f/4G ED VR
AI AF Zoom-Nikkor 70-210mm f/4-5.6D
AI AF Zoom-Nikkor 70-300mm f/4-5.6D ED
AF Zoom-Nikkor 70-300mm f/4-5.6G ED
AF-S Zoom-Nikkor 70-300mm f/4.5-5.6G ED IF VR
AI AF Zoom-Nikkor 75-240mm f/4.5-5.6D
AI AF Zoom-Nikkor 80-200mm f/2.8D ED
AI Ai AF-S Zoom-Nikkor 80-200mm f/2.8D ED IF
AI AF Zoom-Nikkor 80-200mm f/4.5-5.6D
AF-S NIKKOR 80-400mm f/4.5-5.6G ED VR
AI AF Zoom-Nikkor 80-400mm f/4.5-5.6D ED VR
AF-S NIKKOR 200-400mm f/4G ED VR II
AF-S Zoom-Nikkor 200-400mm f/4G ED IF VR
â– High-powered zoom lens
AF-S DX NIKKOR 18-200mm f/3.5-5.6G ED VR II
AF-S DX Zoom-Nikkor 18-200mm f/3.5-5.6G ED IF
AF-S DX NIKKOR 18-300mm f/3.5-5.6G ED VR
AF Zoom-Nikkor 28-200mm f/3.5-5.6G ED IF
AI AF Zoom-Nikkor 28-200mm f/3.5-5.6D IF
AF-S NIKKOR 28-300mm f/3.5-5.6G ED VR
â– Single focus lens
AF-S DX NIKKOR 35mm f/1.8G
AI AF Nikkor 14mm f/2.8D ED
AI AF Nikkor 18mm f/2.8D
AI AF Nikkor 20mm f/2.8D
AF-S NIKKOR 24mm f/1.4G ED
AI AF Nikkor 24mm f/2.8D
AI AF Nikkor 28mm f/1.4D
AF-S NIKKOR 28mm f/1.8G
AI AF Nikkor 28mm f/2.8D
AF-S NIKKOR 35mm f/1.4G
AI AF Nikkor 35mm f/2D
AF-S NIKKOR 50mm f/1.4G
AI AF Nikkor 50mm f/1.4D
AF-S NIKKOR 50mm f/1.8G
AI AF Nikkor 50mm f/1.8D
â– Telephoto lens
AF-S NIKKOR 85mm f/1.4G
AI AF Nikkor 85mm f/1.4D IF
AF-S NIKKOR 85mm f/1.8G
AI AF Nikkor 85mm f/1.8D
AI AF DC-Nikkor 105mm f/2D
AI AF DC-Nikkor 135mm f/2D
AI AF Nikkor 180mm f/2.8D ED IF
AF-S NIKKOR 200mm f/2G ED VR II
AF-S Nikkor 200mm f/2G ED IF VR
AF-S NIKKOR 300mm f/2.8G ED VR II
AF-S Nikkor 300mm f/2.8G ED IF VR
AI AF-S Nikkor 300mm f/2.8D ED IF II
AI AF-I Nikkor 300mm f/2.8D ED IF
AI AF-S Nikkor 300mm f/4D ED IF
AF-S NIKKOR 400mm f/2.8G ED VR
AI AF-S Nikkor 400mm f/2.8D ED IF II
AI AF-I Nikkor 400mm f/2.8 ED IF
AF-S NIKKOR 500mm f/4G ED VR
AI AF-S Nikkor 500mm f/4D ED IF II
AI AF-I Nikkor 500mm f/4 ED IF
AF-S NIKKOR 600mm f/4G ED VR
AI AF-S Nikkor 600mm f/4D ED IF II
AI AF-I Nikkor 600mm f/4 ED IF
AF-S NIKKOR 800mm f/5.6E FL ED VR
â– Macro lens
AF-S DX Micro NIKKOR 40mm f/2.8G
AF-S DX Micro NIKKOR 85mm f/3.5G ED VR
AF-S Micro NIKKOR 60mm f/2.8G ED
AI AF Micro-Nikkor 60mm f/2.8D
AF-S Micro-Nikkor 105mm f/2.8G ED IF VR
AI AF Micro-Nikkor 105mm f/2.8D
AI AF Micro-Nikkor 200mm f/4D ED IF
AI AF Zoom-Micro Nikkor 70-180mm f/4.5-5.6D ED
Merhaba, D5100 'üm var. Karta güncellemeyi aktardım ancak makinada güncelleme çıkmadı. A: 1.01 B : 1.01 L : 1.006 gözüküyor. İşlemleri tüm sırasıyla yaptım ama neden olmadı acaba ? Teşekkürler.
katın içindeki klasörlere değilde direk olarak atacaksınız ve makinanın menüsünden update güncelleme kısmına girip yapacaksınız..
Dediğiniz şekilde yaptım sadece L kısmı 1.009 olarak güncellendi. diğerleri aynı kaldı doğru mudur acaba ? Tek dosya vardı güncellenecek. Teşekkür ederim.
tamam o zaman tek dosya varsa biri olur sorun yok. :)
Bu ne işe yarayacak yani bu güncelleme neyi düzeltiyor amacı ne bilgisi olan var mı?
basıyon exe doyayı indiroyn sonra açıyorsun masa üstüne nikon diye klasör açıyor içindeki dosyayı alıyosun bak bir konu daha açtım d7000 yeni güncellemesi çıkmış onlarıda indir istersen yeni konu açmıştım indir onları istersen
basıyon exe doyayı indiroyn sonra aÇıyorsun masa üstüne nikon diye klasÖr aÇıyor iÇindeki dosyayı alıyosun bak bir konu daha aÇtım d7000 yeni güncellemesi Çıkmış onlarıda indir istersen yeni konu aÇmıştım indir onları istersen
Yok sorun başka bunlarla ilgili değil firmwire ayarlarıyla alakalı. :)
Bu güncelleme tam olrak yazılım güncelleme değildir sistemi tamamıyla etkilemez ve sadece L bölümünü güncellerler. Geniş açılarda'daki bozulamaları olacabıldıgınce engelleme yapan makinanın daha iyi bir Distortion kontrol yapmasını saglıyor.
  • 2 hafta sonra...
dosya bir türlü inmiyor, idiren varsa dosyayı başka bir yere yükleyip linkini yollasa Çok mmenun oluruz.
http://dosya.co/eebf8abaea9ca26f/S-DCDATA-001009WF-ALLIN-32BIT_.exe
rar dosyası çıkması gerekirken neden .exe dosyası çıkıyor? yardımlarınız için teşkkürler şimdiden..
Sıkıştırma metodu SFX modunda olduğu için.
  • 9 ay sonra...
  • 2 ay sonra...
Öncelikle merhaba, foruma yeni katıldım. Makineme son güncellemeyi yükledim. GÖrüyorum ki birden fazla güncellemesi çıkmış. Hepsini tek tek yüklemek mi gerekiyor yoksa en son güncelleme yeterli midir? D3200 C 1.03 L1.009
En son versionu yüklemeniz yeterli.
